Kärcher KB 9030
Condition Notes
On long term loan from @Howard
Induction and Training
Owners
Risk Assessment
Before Use
During Use
The high pressure hose is specially constructed with reinforced walls to handle water pressure up to 11 MPa (1600 psi) - it can be easily damaged and should be stored carefully.
Do not kink.
Do not drive vehicles over the hose.
Do not expose the hose to sharp edges or corners.
After Use
Caution
Only separate the high-pressure hose from the trigger gun or the appliance while there is no pressure in the system.
After operation with detergent: Run the machine for approximately 1 minute for a clear rinse.
Release the lever on the trigger gun.
Turn off the appliance “0/OFF”.
Turn off tap.
Press the lever on the trigger gun to re-lease any remaining pressure in the system.
Lock the lever on the trigger gun.
Detach the appliance from the water supply.
Pull out the mains plug.
Maintenance
Check the water inlet filter is clean and free of dirt and debris!
