Just to update - Andy and I had a good look at the plumbing set up and it seems to be as follows:
The outside tap has a direct 22mm feed from somewhere whcih then goes down to 15mm for the last few feet. This has good water flow as you would expect and will run a pressure washer fine. It will ,however, be susceptible to freezing. In fact, I can’t believe that that pipe hasn’t blown before. The insulation is completely shot. Ideally, you’d drain it if there’s a cold snap.
The internal pipework does not have the same level of flow. This will probably be because of numerous connections and bends in the 15mm pipework that’s reducing the flow. There’s nothing that can really be done about this. I doubt that the flow rate will meet the 6 litres/minute minimum. It’s easy enough to test. Get a half litre jug and see if you can fill it up in 5 secounds. Running a pressure washer without enough water flow will knacker it.
The bath tap arrangement in the silk screen sink area is apparently knackered. I’ll come along and replace it at some stage and I’ll get a replacement with a shower hose attachment. I could also put on a tap point for a pressure washer but I’ll need to check the flow rate first.
Philip
