Tommy #1 (kneeling) approx 180mm high, base approx 300mm wide; cut from 19mm sapele. Finished with 2 coats of danish oil.
Tommy #2 (standing) approx 300mm high, base approx 160mm wide; cut from 19mm walnut. Finished with 2 coats of danish oil.
Clock is cut from 25mm ash; it is for a “special” birthday hence the 1952 coins attached with epoxy. Finished 2 coats of danish oil, a coat of sealer, then finished with a coat of wax.
