Some people have started doing the lining
if we think we will have diff crews working on lining then
can we gert an updated wiki with some photos…thanks
“”“the deadline for completing the lining is: Sun 24 January”""
Seriously though, I think it talks alot/more about the battens, which are almost all up.
it doesnt mention , as far as i can see , that we have put batten screws in at edges so that lining screws must aim for center, I know center is prob where people will naturally screw into.
Doesn’t mention the strip light method? Are we using this, how exactly is it done? to be flush?
Which is the first section of lining per row, I think its the top one, as in the highest, middle of arch??
Is there a difference in method, or are there any tricks to getting side lining on, as opposed to top ones?
How are the ““T”” timbers things used, are they used with the props, did we buy props?
Whats the best tool to cut lining if we need to cut out a section for some reason?
In the below picture, the side uppermost is to go against the brickwork, and the side lowermost is to face out from the brick. Note that the edges must be turned up to catch the water.
