@lasertechs Quick question - any issues with us laser engraving slate?
I’ve had a look on the Trotec website and they seem to suggest that the Trotec Speedy 300 with a CO2 laser is capable of engraving most types of stone, including slate.
100% speed 34%power. If it’s a photo, I would run photo optimised engraving which has a limit on the DPI which I think is 333DPI. This looks at the tones of the image (make it black and white) and adjusts the laser accordingly.
Is this helping?
Do you mean remove large areas to a single depth?
That’s is just straight engraving of a black fill. The material, speed and power of the engrave will effect the depth.
You need to set it to engrave in the bit you choose cut settings.
You can also use colours other than black - and multiple ones to get 2.5 dimensions of cutting. For example this piece I cut recently had 3 different depths of engrave as well as cuts - made out of 3mm acrylic in one operation. Very useable for some applications if you don’t need the precision of milled parts
Yes. Take the text, turn on the full and make it black and you can even turn off the stroke. Print that using the standard settings. Photo optimised is not used in this case.
