Willybood
(Billy Wood)
16 September 2024 06:55
1
Good morning everyone.
When the laser cutter is working again I was interested in trying to laser cut some designs out of some mirrored cardstock. Is that safe to do?
I’d assume not and was planning on buying a cheap vinyl cutter for the project I’m working on, but I figured I’d check if the laser cutter would work. I’ve successfully used it before with card, just nothing with a reflective coating.
asander1
(Andy Sanderson)
16 September 2024 09:17
2
The laser cutter is working again… also we have a vinyl cutter in the Space
Willybood
(Billy Wood)
16 September 2024 10:02
3
Do you know where the vinyl cutter is? I saw some references to it in the Discourse a few years ago but I can’t find it anywhere.
asander1
(Andy Sanderson)
16 September 2024 10:08
4
Yes, it is under the light switches in the textiles / 3d printing room…
Here is the tool page:
Notice
This machine does not require an induction .
This tool may be used while alone in the space.
Model: USCutter MH 721
Condition Notes
USB-B socket delicate, please be gentle! (Replaced socket 28/10/2025.)
Serial port did not appear to work
Embedded Raspberry Pi does not appear on network.
Needs cleaning
Blade replaced 26/10/2025. More blades in shelf underneath plotter.
Maintainers
@nobody
Risk Assessment
Identify risks
low risk
risk of entrapment; keep hair, clothing and extremeti…
tmilner
(Tom Milner)
16 September 2024 10:09
5
In textiles. If you go through the double doors from the messy room its on your left under the shelves.
I am not sure show suitable it is for card (compared to a cricut thing) but worth giving a go
Willybood
(Billy Wood)
16 September 2024 10:14
6
I see it now, thanks @asander1 and @tmilner for pointing it out. In my defence it was hidden under a blanket.
Assuming it won’t work with card, would the laser cutter be OK for that reflective card stock?
Maciej
(Maciej Kamiński)
16 September 2024 10:37
8
Are these cards reflective on both sides?
asander1
(Andy Sanderson)
16 September 2024 10:39
9
Yea, not your fault, we need to add a photo to the tool page at a minimum!
Oday
(Oday Mansour)
16 September 2024 11:32
11
I’ve cut mirrored acrylic by cutting the back of it making sure to mirror the design. It came out great!
Willybood
(Billy Wood)
18 September 2024 07:12
12
I just finished a test cut. It took a couple of attempts to get the settings right, but it looks like the laser cutter will work for this.
I only tried it with the reflective side down JIC.
