Greetings,
I have built a platform which is functional and suitable for tool maintenence.
With a platform larger than a postage stamp a grinder is an indespensible tool in a workshop setting, how else would you maintain tools…on a water stone?
Our tools get damaged, we now have an effective, speedy way of reshaping and grinding primary bevels on virtually every tool in the woodshop.
A decent grinder also makes it possible to try stuff out, if you don’t like it you can simply change it back.
I recently changed the profiles on a couple of skew chisels which were not getting a lot of use. Now they are better suited to my needs and I use them regularly. I simply would not have been able to do this without my own grinder.
My blades take seconds to raise a burr because I grind the primary bevel when it gets too big. The time savings are real.
I was reading the Chris Schwarz book on stick chairs recently. Grinding is mentioned very briefly. It goes something like this, " If you are a woodworker and you have tools, you need a grinder…duh! "
Using my own grinder I have made custom scraper blades, spur point drill bits, radiused plane blades, I sharpen all my turning tools and maintain all my bench blades, the options are endless.
The space grinder offers limited access to the wheel so I have done the best I could with what I had. Presently the base needs to be clamped down to negate vibration, I will add some rubber feet later to see if it dampens the vibration. I may fine tune the height of the platform in the future.
I suggest giving it a try, I am happy to demonstrate. I know a great deal about grinding woodworking tools because I do it regularly.
Grinding requires basic hand eye co-ordination.
Contrary to popular belief grinding with a platform is not really freehand grinding and it is not difficult to accomplish, so long as you check progress to ensure you are achieving the correct grind, it is totally intuitive. The platform is a jig, directly comparable with using a honong guide. One imparts motion, sets an angle and references a tool. If you want more material removed from the toe of the tool you tap the toe of the platform and visa versa.
Above all, using the grinder is fast, efficient and fun.
It would be beneficial to purchase a coarse grit ceramic wheel (46 grit) and a fine ceramic wheel (100 grit) as they are faster and they grind cooler than most other affordable options. Ceramic wheels would be good for metalwork and woodwork applications and they last a long time with a reduced tendency to load. A 40 pound expense seems like a small price to pay for such an indespensible tool.
The grinder is in the welding area at the moment.
I will definitely be using the grinder. If you have any questions please ask.
