Electronic Consumables (II)
Hi @electrotechs,
I am new to the space and just wanted to check use of consumables, I saw this electronics post but it’s quite old now so wanted to double check.
Is it still correct that if its there and unlabelled its generally for member’s use? Currently trying to fix a rice cooker so thinking about things like hook-up wire, crimp connectors, heat shrink.
Thanks!
Hello! Yes, you should be all good to use consumables like that.
Good luck with your repair and hopefully see you in the space soon :slightly_smiling_face:
Mia
Thanks very much!
