Brother innov-is 1500 Embroidery Machine
Notice
  • This machine is currently out of order.
  • This machine requires an induction.
  • This tool may be used while alone in the space.
  • built in embroidery patterns
  • Quick set bobbin
  • Automatic needle threader
  • Black and White touch screen
  • 12.7cm x 17.78cm (5x7 inch) or 15.25cm x 25.4cm (6x10 inch) embroidery area
Condition Notes
Second hand - Acquired by space (fully serviced) - Feb 2025
Induction and Training
No induction needed.
Maintainers
@textilestechs
How To Use
Before Use
The machine does not have a USB-A port, so you cannot plug a thumb drive into it for file transfer. Instead, use the USB B to A cable and connect to a laptop. It will show up as a drive device on the computer.
Save the your embroidery design file (in .pes file format) onto the drive. On the embroidery machine, press the computer/usb symbol on the bottom right and select your file.
Position the pattern within the grid as desired. Please refer to the manual for more details.
During Use
After Use
Risk Assessment
Sewing Machine / Overlocker Risk Assessment
References
User Manual.pdf
Notice on Bobbin Cases.pdf
Quick Reference Guide.pdf
Innov-is 1500 Service Manual.pdf
Innov-is 1500 Parts List.pdf
