Bike Repair Stand & Bike Tools - Park PCS-10
Park PCS-10 Bike Stand
  • Cam-type clamp allows single action clamping of tubes 7/8" to 3" (24mm to 76mm)
  • The clamp jaws are nominally 3.5 inches (9cm) wide; Will also clamp on aero shaped seat posts
  • Clamping pressure is fully adjustable and jaw covers are replaceable (part #1185K)
  • Three-point leg system with reinforced center yoke for superior stability
  • Composite top tube for smooth 360-degree clamp rotation
  • Spring buttons lock folding legs in place
  • Exclusive receiver pod accessory system integrated into the top tube and height adjustment collar to allow easy installation of PTH-1 Paper Towel Holder
  • Height adjustment collar accepts #106 Work Tray
  • Quick-release height adjustment from 39" to 57" (99cm to 145cm)
  • Folds down to 41" (104cm) for portability and storage
  • Base when open forms a triangle of 36" x 36" x 45" (92 cm x 92 cm x 115 cm)
  • Weighs 17 lbs. (7.71 kg)
Misc. Bike Tools - for most bike tasks:
Condition Notes
Purchased new by pledge drive in August 2017.
Induction and Training
N/A
Maintainers
@hernehillier, @charlesmein
Risk Assessment
Before Use
During Use
Can use in messy or clean room.
After Use
Put back in messy room by door.
Maintenance
References
PCS-10_instructions.pdf (1.1 MB)
