Band Saw - Axminster 250
Tags: #<Tag:0x00007fa4a3a6fbb8>
NOTICE: This machine must not be operated without induction
NOTICE: This machine must not be used without the presence of another member in the workshop.
NOTICE: PPE must be worn at all times during the operation of this machine.
Manufacturer: Axminster
Model Number: AWHBS250N
Max Depth Of Cut: 120mm
Max Width Of Cut: 245mm
Max Width Of Cut With Fence: 145mm
Condition Notes
Bought new May 2014
Cosmetic damage to plastic vertical post cap
Induction and Training
Do not use this machine without first being inducted into its safe use.
To attend an induction, check the Events category for the next session
A list of trained members and their induction date is to be kept in the machine’s cabinet.
Owners
The following people are responsible for maintenance and training
@tomnewsom
@unknowndomain
Risk Assessment
Identification of hazards and risks
  • Work pieces jamming - Medium
  • Hands and fingers can contact wood being turned - Medium
  • Clothing/hair can become entangled - Medium
  • Wood dust can be inhaled - Medium
  • Noise damage - Low
  • Inadvertent starting of the machines - Low
  • Ejected chuck keys, drills, swarf, work pieces, etc. - Medium
  • Unexpected spinning of hand held workpieces could cause injuries - Medium
  • Cuts - High
  • Lack of space around machine can lead to operator being pushed by passers by - Medium
  • Slips due to slippery floor surfaces - Medium
Control Measures
  • Ensure space around machine is clear of obstructions and the operator does not block access to other parts of the room
  • No loose clothing to be worn. No jewellery to be worn. Long hair to be tied back.
  • When cutting for extended periods of time, wear the ear defenders provided
  • Ensure guard is in good working order and lowered to reveal minimum required height of blade.
  • Ensure that the guide rollers and thrust wheel are aligned correctly with the blade.
  • Push sticks to be used instead of hands when close to blade.
Before use
  • Ensure blade is tight and unbroken
  • Make sure that your work piece is not thinner than 3 tooth blades; thin pieces can catch on teeth and be thrown out.
  • Lower guard to minimum height required for your work piece
  • Ensure thrust bearing is just away from back of blade
  • Ensure guide bearings are nearly touching, but not gripping the blade
  • Ensure that the back of the blade teeth will not touch the guide bearings when the blade is pressed against the thrust bearing
  • Check that the area around the saw is free of obstructions and trip hazards
  • Remove all loose jewellery and clothing and tie back hair
  • Wear appropriate PPE equipment
  • Do not wear gloves; they can get entangled in the blade
During Use
  • Do not cut without extraction running
  • Do not keep the blade running while not cutting
  • Stand with feet apart and move the work piece slowly through the saw with both hands
  • When pushing the piece close to the blade, use a pusher stick
After Use
  • Tidy up any dust/chippings that were not extracted
  • Set the guard to its lowest extent
  • If you set a non-zero cutting angle, re-set the bed to level
Maintenance
NOTICE: Before performing maintenance on this device ensure it physically isolated from the mains.
  • The maintenance should be performed weekly.
  • Check for signs of cable damage.
  • Check for signs of damage to plug.
  • Check the NVR is operating correctly.
  • Check the blade:
  • Ensure there are no cracks in the blade
  • Ensure the blade is tensioned correctly.
  • Ensure the blade is tracking straight.
  • Ensure the blade is sharp and suitable for wood and plastic cutting.
  • Check thrust wheel position
  • Ensure safety notices are present and legible:
  • PPE notices (Eye protection, dust mask, ear protection).
  • Risk assessment (Is it up-to-date?)
  • Induction requirement
  • Usage instructions
  • Maintenance sheet
Reference
HSE - Safety in the use of narrow band saws (Woodworking Sheet 31)
