I’m playing around with a couple of project ideas and had the idea of making a layered acrylic wall light with a backlit translucent panel (the idea being that the engraving is only visible when the light is on). Anyone have any recommendations for LED strip lighting? I have an idea of what I’d like to do but I’m worried about getting an evenly diffuse light from LED strips.
There’s various diffusion available that might work for you - I’ve used it in film lighting situations, but not exactly what you are doing. Something like this might be the thing to look at:
Best to find a local specialist lighting supplier and have a look (a lot of film ones in Soho and West London - also see from who has these online).
Greaseproof paper and various fabrics also works - used that too in low budget situations - but be aware of safety/fire risks.
Best diffusion is using principle as in soft box lighting- light directed to a reflector that bounces to the diffusion rather than light directed at the diffusion.
I’d also consider maybe hacking the backlight of a broken laptop.
Backlit - it’s a bit of an experiment. The below shows what I mean - translucent porcelain in 3d relief gives you different tones, and I was wondering if anyone had tried the same with a thin translucent acrylic…
This might be a case of have a go and see how I get on!
Now that the target has received their gift I can post pics of what I managed to put together - although the result wasn’t quite what I originally had in mind. I engraved one piece and sanded the reverse to frost it, and then stuck two more layers on the front with cut outs.
I did have one minor issue with one of the profiles which I traced to somehow ending up with a triple profile, so a couple of the pieces have some burning on them. All in all a great reintroduction to the laser cutter!
