Hi, I’ve been actively using the woodwork space for a couple of months now on a regular basis and loving it! The community of makers with so much knowledge to share is inspiring.
Hope its OK to make a couple of suggestions about the space.
The lights are on a PIR (passaive infrared sensor) and go off if it doesn’t detect movement for a period of time. On several occasions I have been operating the chop saw or a router and the lights go out. Mid way through a cut this can be really dangerous. I understand its to save energy, but surely safety would come first.
Can we bipass the PIR and just have the lights on?
I also clear the bench at the end of my day even if I’ve glued up and likely to return the next morning. I wouldn’t want another member to have the responsibility to move my project and find somewhere to safe to place it. Can we adopt a clear bench at the end of the day. If work is glued up it can be rested on its side.
As I say, I love working on my projects here, and very happy to help, share my knowledge and learn from others.
Thank you
