Hi @woodtechs I ran into an issue centreing a hole for a project that I was turning on the lathe. I had originally planned to turn the shape for a handle, then drill a hole down the centre, however aligning the hole with the axis of the part ended up being much harder than I anticipated with the drill press.
I had the thought that instead I could drill a small pilot hole through the blank before I start turning, and use this through hole as the centre points for the lathe, and by doing so ensure that the hole is always concentric with the shape I am turning.
Then I could widen that hole to the desired diameter after turning, which should guide it to keep it more central (hopefully)
I would like to check if this process is recommended? It occurs to me that a small hole in the centre could potentially weaken the part as it turns, potentially leading it to split while spinning? I might be over-emphasising that risk though, as it would be a very small diameter hole. What do you think?
