Woodshop not turning on
@woodtechs Does anyone know why the woodshop tool control is not activating at all. If I scan the fob it says all is good but on pressing the buttons nothing happens…
Is this a thing with a known solution?
Check the circuit breaker box to the left
No shit Sherlock! That did the job. Thank you.
This happened again today, I’ve reset the breaker - is there an ongoing issue? It was the far left breaker in the white cabinet that had to be reset.
@joeatkin2 can you take a look?
@woodtechs
Hey guys, this is happening again this morning. I checked the circuit board but all good there.
I can come by in 10-15 mins to look at it
Hi @mbg no rush
Resolved by Joe. Contact cleaner sprayed into the estops. Ended up being the one by the extraction
