Wood wouldn’t work
Tags: #<Tag:0x00007fa48d1a3810>
@woodtechs and @directors as it might be a systems issue.
I tried to use the wood shop a couple of nights ago, but nothing would energise. Tool control took a couple of seconds to log in and out, and there wasn’t much happening after I hit the black button on the power panel (eg, extraction didn’t turn on).
Presumably it’s all working fine now?
I’ve seen issues in the past - where tool control worked, but the shop didn’t fire up - because an emergency stop button had been used and not reset. Check all the emergency stops have been reset (and there’s no issues/hazards) and try again.
check the white fusebox on the left of the poweron box, there is often a flipped fuse in that (I have had this happen 3 times)
