I’m making this cabinet in 9mm ply. I’m not sure about the joins between a) the base and the front panel, which is 10 degrees off the vertical, and b) the back and the top panel, which is 10 degrees off the horizontal.
On possibility is to cut slots into the side panels with a router, and slot the base, back, top and front panels into them. Then I could just have glued butt joints at 10 degrees where required.
Or is it possible to do router cuts accurately at an angle? @Jonty_Bottomley ?
How would you do it?
