Hello @lasertechs I’m having a problem here. I’m trying to cut some plywood 6mm. Save exact settings I used before Christmas and same exact birch plywood from kitronik (laser grade). Cut this material several times before on this machine with the same settings and never had any problems!
Any ideas why this is happening?
Also, the laser had has gone a bit dark because of the flame, is there anything I should do?
Ensure settings in the dialogue box when you click ‘print’ in coreldraw (or equivalent) are what you need. Go to “properties” and check settings are correct for your use. Then click “print” which will launch tool control - again check settings are correct
Yeah, there’s a whole bunch of hose on a self retracting reel somewhere as well. Neither of the compressors in the space are quiet though (or necc work).
FYI in case it’s not obvious don’t blow air into or anywhere near the laser cutter because the dust will settle on the mirrors and lenses which are deep inside the machine and are usually protected from dust.
