The microUSB port on the Wemos will be used for uploading code.
I could connect a microUSB male to the charging board and then manually swap between the charging USB and the code upload USB but that feels clunky.
I could directly supply 5V from the charging board to the Wemos (via 5V VCC rather than the USB) AND the servo AND the motion sensor separately, but I lack the electronics knowhow to think through the wiring.
Oh your taking about the things that interface to it. Yeah, you don’t want to drive the 3.3v inputs on the D1 with 5v outputs. The reverse can usually work though. The D1 outputs can likely drive units on the peripheral boards.
Thanks for the input.
I realised that I haven’t explained myself very well (hopefully the diagram helps).
Thanks for the reminder about OTA updates.
For other reasons, I still want to keep the USB port available for upload.
