@Howard made some calculations yesterday, they need 5v / 7A to drive all the LEDs at the same time , and you will need a beefy MCU to drive it all the ((1024 x 8 bit) x 3) LEDs , the good thing is that is basically glue logic so the speed is limited by the MCU.
this thing scream jumbotron or at least the brightest installation for the next EMFCamp.
I like the look of these but they still aren’t what I’m looking for for Luke’s iBus display. By the time I find the right led matrix they’ll have moved over to LCDs!
There were 4 boxes donated to hackspaces - 3 boxes went to 6 LHS members in the end and the other one was split between you and Wembley as Wembley is dormant at the moment you got 2/3 of that box - two of the guys who took a box then realised they had more than they wanted and spread it around a few more people, so Tom if you want another 10 let me know - if you can collect I am fairly often at SMEE which is a round the corner or LHS
actually I missed an important point that these were donated / made available to Hackspaces through Tom of http://www.digiled.com/
Regarding driving the boards to quote Tom
"Alternatively, if you’re happy to buy off-the-shelf kit, you can purchase the controller cards (we call the scan cards) from the web here : http://www.led-card.com/led-receiver-board.html
To quirt video into these cards you’ll then need an LED sender card (think of it as a DVI capture card to convert to LED tile protocol) : http://www.led-card.com/led-sending-card.html
Originally these LED panels ran on the Linsn family of Sender and Scan but there’s no reason you couldn’t go for the more common NovaStar or similar instead.
All you’ll need then to light them up is a hub card (to distribute the power and data from the Scancard) and some 5v DC power.
Whats left in the space is exactly enough by my estimations to make a 1M by 1.25M display (40 panels). which would require:
300A / 5V power supply or supplies
2x receiver cards
1x sender box
1x computer with DVI/HDMI output
Wiring
A few people on Telegram said they wanted to set one up at Makerspace, if that is the case it would be good for them to come forward and steak a claim before these end up disappearing into people’s personal hoards.
That would be really cool but we don’t have the space and run it would be expensive, I honestly think that would be great to make small project out of them instead of one big.
I’m getting in the software side of it, I’m planning to use mbed with a lpc1769, should be fast enough to pump data to the screens.
Thats perfect, I’ll take the rest of what I needed and whats left will be available for members to use, or I will dispose of them through WEEE or London Hackspace members in 2 months or so.
