Hi all, does anyone know the status of the vinyl cutter large and small and also how easy it is to get up and running with these tools?
Thanks.
Jonathan
Vinyl cutter
Large one works well, but only used it with Linux following the instructions on its page…it did seem like someone had adjusted the rollers (unfortunately, as they were set up perfectly), I think it will work on a Mac using InkCut part of InkScape
Reports are the small one is playing up, but not tried it for a few months
People who’ve used either or both recently: @peter_hellyer @Esther_Gladstone @Ty_design
I’m interested to see that working and help if I can. Let me know when you’re going to try.
Bump.
Anyone know if the vinyl cutter is working?
Big one yes, @Howard was using it very recently
The small one doesn’t seem to be working… need to check it out…
Is there a vinyl cutter induction process?
You don’t need an induction for this, and there are quite thorough instructions on its tool page…but shout out if you need support
