Is it safe to use the laminate linked below on the laser cutter?
https://hobarts.com/m/prod_listing.php?cPath=124_6#/m/prod_detail.php?cPath=124_6&products_id=992
Hobarts is a laser materials supplier, this is laser signage, my understanding is you edge the top off to reveal the lower, however they are very friendly if you ring them they can tell you for sure as there is no MSDS or details about what the material is a laminate of.
It’s laserable laminate, I’m sure it will be fine. Engraving and cutting this stuff is actually what these newfangled laser ‘cutters’ are designed for…
I’ve used it a bit, and when you get the right settings you can get some excellent results.
I wasn’t 100% as they also make this in CNC mill format too.
