Tube light in phase 2 flicking on and off
Hi there is a ceiling light in phase 2 that keeps turning on and off, like it’s dying. Do we have any replacement tubes / does anyone know how I can put it out of its misery in the short term or what we can do to fix it? It’s quite annoying…
well if you throw something at it that will stop the flickering :smiley: jokes
You can unplug the top lights
Back left, looking from the entrance? I think we tried the tubes we had when we did that… back, cor, at Christmas? Given Phase 2 works imminent, probably best just to remove it.
The reason the lighting was disconnected was because we were getting ready for construction, I would suggest that happens on Sunday, stripping back the space to what we need for construction.
I wouldn’t disconnect the lights until we have an alternative… Otherwise it might be dark in there. The power in phase 2 lights the snug and supplies/lights woodworking night.
The first job is the wall. Phase2 is big, with planning we should be able to ensure there’s still enough space for woodworking night to continue through much of these build.
