Hello. Just a heads up.
If you use the compressor and need to pull it out from under the tablesaw table, please make sure when you put it back you check to see if it dislodged the tablesaw extraction.
It was off today and there was wood and sawdust built up at the entrance to the extraction.
On that note, if you are using the tablesaw, check the pipes at the same time you check the gates. Thanks.
