Sunday Bandsaw Help
Tags: #<Tag:0x00007fa49a80fbb0>
Hi @woodtechs, is anyone around this afternoon who could show me the bandsaw/help cut out the sash horns on the window frame I’m making please? I think the tightest bit of the curve has a 16 mm radius so should just be ok with the narrowest saw blade. This is the existing shape which I’m hoping to replicate
You could match that shape exactly on the CNC - an alternative to consider. It wouldn’t take long. If you want to do it that way, and not inducted, I could help you with that - I’ll be in at about 5pm.
Thanks Dan, I did wonder about the CNC - I’ve only done the mini cnc induction so help on the big CNC would be very appreciated if the bandsaw isn’t an option. I may also have a look at the scroll saw. Should be at the space from around 5pm/5:30pm too
I believe @Federico may be around at that time too,if so, I could induct you on the big CNC under his supervision and to qualify as inductor for the big CNC. Also happy to help with that. My eta is currently 5:30 (train disruptions).
Great, I’m just in the clean room and will have a go creating the template for the cut.
