Storage Request - espresso machine
Whilst I am rebuilding a espresso machine I would like to be able to store it at the Makerspace. It is 400 mm deep, 400 high and 700 across. Storage is required until I finish rebuilding; so until the 4th of Feb to be pessimistic.
In the event that I can not finish it by then I pick it back up before the 4th.
Alex
4th of Feb? :smirk:
Sorry 4th of March…
Fine by me
Hi Alex,
Good by me, but as Nico pointed out – that can’t be the correct date?
Where items are stored is important, unless it’s too large – or some other strong reason – projects should be stored in the snug, on the left hand side as you go in.
I thought we had a storage request template…but can’t see it anywhere.
However this is the format that works well…
Description of storage request (include dimensions)
2 sheets of MDF cut into pieces to make a toy storage unit. When assembled it will be 1.5 x .50 x .60 metres.
Storage Location (be precise)
In the snug to start with. I am hoping to assemble and then paint it on sawhorses in the messy room.
Start Date (be in the future if possible!)
Tuesday 20th December 2016
End Date (be pessimistic)
3rd January 2017
Hi Dermot,
Ah that’s what that was! I thought it was glitch of some sort and someone else’s request had automatic drafted itself into the text box!
4th of March, sorry mental calendar still catching up :wink:
Last time I looked in the snug there wasn’t quite enough space for it on the left hand side. Also it will get heavier as I rebuild it and soon be impossible for my to move on my own. I was thinking I could build a wheelie bench first perhaps.
Alex
