I would agree with you Joe! but thing is I did buy another one which is not “limited”, and has a peak performance of 6000W as they said and it’s got even slower max speed then the original… however acceleration was amazing
- was even thinking about replacing the micro controller with custom software but that’s even a bigger project… as first I would need to analyse how the signals are used and generated… and so on
I would be happy if I wouldn’t have to buy more battery cells, a new BMS and a charger for this, as the lithium-ion battery pack itself was about 700 pounds
The limiting factor may be the output devices or the motor inductance or a whole host of things.
This sort of thing was rocket science a few years ago. What I am trying to say is it might be a bit more difficult than just pumping up the voltage.
If you catch me in the space I will be happy to help
Do you have a drawing of the controller?
I don’t have a circuit drawing for any of the controllers
. but I can drop by with the one I’m not using currently
They are probably based around a chip jus get the datasheet
It’s a 16 bit nec microcontroller.
Its all in software
Thx… Got it.
Maybe I can replace it with an Arduino ?
Probably not powerful enough .
There’s a good application note from microchip An857
Google "microchip an857 "
Happy reading
Brushless motors are rated in revs/volt so more volts = more revs. The current (amps) is the horse power…
volts x amps = watts so that’s the correlation.
I’m back in the uk and should be at the space for Thursday Electronics!!
Courty
Sarcasm is the lowest form of wit
At 6kw I am pretty sure it is not that simple.
But if it is i am prepared to eat my hat …
While it is an over simplification, fundamentally the above is true !
Courty
I definitely got the inpresion that the limiting factor was not the motor inductively, I got the inpresion that it was probably the inverter, but I will still Google what goes best with hat
okay… I talked to the guy I bought the controller from and he advised not to increase the voltage above 80V. Now max voltage on the li-ion battery is already 84 volt and it gave me 1 mile of increase in speed. So bad news is if I want to increase the voltage I’ll need more cells, a new BMS and a new controller… not the news I was expecting as this will cost another few hundred pounds
probably… But I was not able to find the datasheet
