DAC17
(Dale Connolly)
6 December 2017 06:16
1
Sorry, completely forgot to post yesterday!
I used the shop vac fine for a short while yesterday. However, when I tried switching it on a little while later, nowt happened.
Tried it in various sockets, but no joy.
Didn’t have time to switch the fuse out as I had to rush, but meant to post this after leaving.
Apologies.
@woodtechs , unsure if this has already been reported?
I had some trouble with it as well but got it working again. Sounds like a loose connection?
DAC17
(Dale Connolly)
7 December 2017 07:12
3
Afshin said it may have been full up. Not sure if it has some sort of cut-off to ensure it’s not used whilst full. Either way it was working last night, which is decent.
afshind
(Afshin Dehkordi)
7 December 2017 14:20
4
Funnily enough it wouldn’t switch on after I said that!
Turned out to be loose connection in plug, might just need opening and checking. I can do it next time I’m in…was in rush.
DAC17
(Dale Connolly)
7 December 2017 15:01
5
Typical…
That’s the problem - you generally use the vac last thing before ducking out and are in a hurry!
Hopefully someone has a little longer to have a look at it and see what’s what.
