hi, I have 6mm thick plywood, please see photo, small pieces and want to round off the edges. Can this be done on the sander? Doesn’t have to be a specific angle or anything. Do I need an induction to the Wood workshop to do this? thanks
Maybe cut a template on the laser, then use a guided router bit to follow the profile you want.
You can then use a guided round over bit to get the edge profile you want?
Will be a lot more consistent and neat than trying to do it with the belt/disc sander freehand… IMO
Hope that’s useful!
Router would be needing an induction I think, but sander is fine with the general woodshop one I reckon. Easiest would be the big belt sander or clamp it and use the orbital - might need to buy sanding discs.
Thanks all! Julia showed me how to use the sander
