I made a laser-cut rubber stamp once, I just use it with a normal stamp pad? (I also laser-cut a wooden handle to help me use the stamp). 20x20 might be a stretch though, I guess what you’re making is more like linocut? In that case, I’ve used acrylic paint with a roller.
Might be obvious but remember that you need to flip your design to make a stamp, otherwise your design will come out flipped when you stamp it
What’s the final use for the rubber stamp you are making? Is it a short use stamp or are you planning on using it a lot? It might inform the sort of rubber you get and the way it is made. If you want something that is getting alot of use then there might be certain considerations to make. I’m guessing you will be using something like a rolling press for something around 20cm square? I can give you a few recommendations on material for things like Lino cuts but completely depends you your final use.
As mentioned, you want to remember to flip your design and engrave the negative of what you want the stamp to show. I used contact cement to affix the stamps to a wooden block. The settings I used should be something like “mbg rubber” on the machine
I’ve always used the rubber from here: https://hobarts.com/collections/rubber
It engraves really well. (flames around the laser head area are normal when cutting engraving rubber, air assist must be stitched on!) Also, remember to mirror your image.
Do you need to do any postprocessing once the engraving is finished, other than mounting it onto something?
And do you need to adjust the engraving “depth” to optimise for rubber? (not sure if that’s even possible, I’ve only done a couple of beginner projects so far where the settings had already been set by someone else).
I feel like I’m going mad. Or maybe everyone just enjoys doing all this manually.
There is a specific option to optimise for stamps, one that mirrors the image, adds a ramp to sides for support and engraves to the correct depth for the right material.
It works really well and it’s just in a drop down menu when you want to cut. The manufacturer of our laser cutter started in the business by making… stamps.
It’s been previously mentioned that cutting rubber leaves a mess - is there any advice on how to minimise this? For example, Brian here is suggesting that we put something underneath. What would people recommend that we lay underneath?
Also, if you’re using Adobe Illustrator for your stamp design (or any other design that you’re laser cutting/engraving):
Create the design in .ai
If the design has text, then click on it, go to Type -> Create outlines (otherwise your cool font might be converted to a simpler font)
Scale the design by x1.333 (some weird issues with resolution when converting .ai to .svg making your design smaller than it should be. Explained in detail here)
Click on the design, then click on the Artboard tool, then Fit to Selected Art
File -> Export -> Export As -> .svg
This is the only way I’ve found that works for Illustrator - if anyone has a smarter workflow please let us know
