I’ve been doing some work on the RF front end for the LoRa modules in my wind monitoring system.
I’ve sourced some really nice waterproof 4Mhz cavity filters.
https://www.aliexpress.com/item/1005004141233710.html
These are not directional and have an insertion loss of between 1 and 2 dB
I was doing some research and came across this setup
I thought that this would suit my needs without the Power Amplifier and with the cavity filter in place on the Low Noise Amplifier. The idea is that this should give a lower insertion loss on transmissions as they do not go through the filter but with properly filtered reception. I also had a couple of circulators in stock.
So I made this:
But the results are not what I expected…
The transmission path is great with a flat insertion loss of 0.5dB but the return path is not what I expected!
It looks like the circulators are leaking around the filter. I tested them with a 50 ohm load, and they work as expected.
It was an interesting test, but sadly not successful!
What have I misunderstood?
