@lasertechs have added at group of ‘recommended settings’ to Ruby for use with the Trotec Speedy 300 laser cutter
- You can find them by searching ‘0. SLMS (Material) (Thickness)mm’, eg ‘0. SLMS Plywood 3mm’ on Ruby
- Suggest new official material settings by replying to this post
- Please keep the materials list below in alphabetical order
- See the bottom of this Wiki for related posts
Conventions
- Colour convention for these settings is Red=Cut, Black=Engrave
- 1 pass cutting, 2 pass engraving
- 75-90% power cutting for less burn
- 10,000Hz cutting, unless max power required
- For laminates, cut first, then remove film for engraving
Recommended Laser Settings Currently Available in Ruby (alphabetical order)
Setting Name | Last Updated |
0. SLMS Acylic Laminate 1.5mm | 230713 |
0. SLMS Bamboo Venir 3mm | 230713 |
0. SLMS Corrugated Card Single | 230723 |
0. SLMS Corrugated Card Double | 230723 |
0. SLMS Greyboard 2mm | 230620 |
0. SLMS MDF 2mm | 230718 |
0. SLMS Perspex 10mm | 230618 |
0. SLMS Plywood 3mm | 230723 |
0. SLMS Plywood 4mm | 230723 |
0. SLMS Plywood 6mm | 230718 |
0. SLMS Plywood 9mm | 230718 |
Related Posts
- What the Settings on the Laser Cutter mean
- How to work out laser settings for a new material
- Trotec Speedy 300 laser cutter
- Laser Cutter Induction Waiting List
