Not posted any projects for a while but thought you might like to see something I made as a Christmas present.
Text
Text
19mm thick piece of sapele approx 20cm wide using maxi tealights.
Disc in the middle cut at a slight angle so it drops down and creates the raised “stand” underneath.
Words & star design cut on the scroll saw.
A little sanding needed but a lot had been done to prepare stock previously.
Edges rounded over with the router.
2 coats Danish oil, then wax & elbow grease to finish off.
Well received by the recipient - certainly an idea/ design I will use again. Concept was from a pattern I’d bought, but text & layout my design.
