Random filament stub in ams
Hi @3dprinters @3dtechs
There was a bit of filament jammed in the ams of the orange bambu today. Looks like someone was using it, powered off everything, then realised they’d forgotten their roll and it snapped trying to get it out of the ams.
Once I tapped in and powered it on, the ams ejected it, but I wasn’t sure if it was safe to use so used the pink one instead.
I only thought to take a pic half way through this, but when I first saw it was just a little nub.
Is this a problem or is printer fine now? I wonder if it’s possible the ams are off tool control, but the printers aren’t. That way you still need to tap to use, but if you want to load or unload from another you can. Probably an edge case to be fair.
Yes not the correct way to unload filament. At the end of the job the AMS should retract the filament.
@3dprinters
Please make sure to leave the printer on for a few mins after your print is done so it unloads correctly and is ready for the next user before tapping out.
