I’m removing a radiator, and the connection at one end is as shown. I’m wondering how to close the valve? As you can see the central part is not designed to be closed with a key, it’s cylindrical. The nut below the top part doesn’t seem to be turnable either.
I’m guessing this end is for the water exiting the radiator. Is it an automatic valve? I was able to close the valve at the other end no problem.
I will find out when I turn the mains water back on…
