Have got a clockmaking project in a couple of months that requires some thin bits of wood and wondered if this might be the tool for the job - but I have no experience or knowledge of it’s capabilities/or how it works - so got a couple of questions - had a browse through the pdf’s but didn’t really find many answers.
Is there a limit to the width of boards (and what is it?) (i assume the limit to length is the length of what you can fit in the woodshop…)
I gather you can cut pretty thin boards by sticking your board to another one (with double sided tape) then running it through - is this fairly easy/possible to get 1mm board out of a typical hardwood? Is the tolerance on thickness with our machine reasonable , maybe need ± 0.2mm? Flatness isn’t especially important, just that the thickness is consistent.
another idea related - is it capable of cutting acrylic impregnated stabilised wood, e.g https://stabilizedwoods.com/ - says you can mill it so I’d imagine it would be ok but not 100%
Cheers!
