I have some reclaimed (and nail-free) boards that could use planing, with the idea of turning them into a work station / desk top.
Do we have a planer and is it operational?
(I found a post from May last year suggesting it’s not been commissioned, but the photo has a planer different to one I think I have seen at the space).
Hi Luke. The current rule on reclaimed wood is that people use the hand planer and bring a stack of their own cheap blades - this is largely because the big planer/thicknesser has very expensive knives. The short story is that reclaimed wood is prohibited on the planer/thicknesser.
If you’ve not already been inducted it’s worth getting your name on the induction waiting lists for a workshop induction. If you’re building a desktop out of planking then the hand planer and sander should do the job, and they are covered in the first induction.
Hello lovely woodtechs - I would love to use the thicknesser, can I ask what width of boards it accepts? I came into the space on the weekend but it was hard to ascertain. If I have boards under 300mm wide, am I correct in thinking I can slide them through in one go, and wider boards would be more of a handful as perhaps would only plane half of one side of them (e.g. 4500)? Just checking as I’ll pay the timber yard to plane the big ones if so.
Maximum width of the thicknesser is 12" which is a hard limit - you can (maybe?) joint half a board, flip it and do the other half but the thicknesser is strictly 12" as the body won’t let you put more than that through. I would get the timber yard to plane the biggest ones or use a router sled (a la Nick Offerman - link)
I mean, if it is me you are asking I would say grab a hand plane and a few thousand calories and go to town on it but I can probably see the appeal of power tools in this situation.
Also worth noting if you want to use the planer/thicknesser - last time I saw it the fitting for the hover sled was still missing, which would make it hard to use. @joeatkin2@lewisss - did you find a replacement?
