Planer thicknesser abused mat
Hello @woodtechs ,
I just noticed that the mat under the planer thicknesser has been abused and/or last user hasn’t used the compressed air to try to hoover it back to rest position, leaving it right there.
The rubber has now holes and cuts.
Thanks for letting us know. Is it still possible to move the planer with the hovercraft or is it stuck now?
I would say it’s stuck.
I tried to clean under the mat with some compressed air. Then tried to move it, but it’s exposing more holes and there is also a piece of wood stuck underneath the planer.
By the look of it the mat needs a replacement.
Thanks.
thats a bummer - I haven’t been inducted but am happy to come over, chip in and help replace put new one in - lemme know when it needs to happen.
I can help woodtechs repair this Sunday afternoon late afternoon
Hi Emanuele, I didn’t see this until this morning. I used the planer thicknesser on Monday. I didn’t abuse the matt, it was like this already - I’m sorry I didn’t highlight it to the woodtechs, I would be happy to help @woodtechs fix the problem.
I did try to pull the matt flat to improve the situation whilst it was levitated with the gas, but it didn’t work.
I did clearly leave it quite pushed out sorry, because the folded matt was blocking it, not good, won’t happen again. I will highlight issues like this in the future.
Hi Hannah,
please remember to report to woodtechs any time you will incur into issues with any tools and machines. Then stick a label on the tool stating it’s out of order. This is to speed up fixing and repairing operations and also to let the community know, so they won’t book and travel distances to get to the makerspace to then find out they wasted huge amount of time for nothing.
SLMS is a community where everyone is affected by other members behaviours and tool malfunctionings. No one is here to blame or pointing fingers; but please let anyone else know the tool is out of use.
Thank you.
Hi Emanuele,
I will of course flag these situations to the wood techs in the future.
As it was just a corner of the matt, and the machine was still on the matt, I didn’t think it was necessary to flag that the entire machine was out of order, but perhaps I was wrong.
Thanks, Hannah
Hi Hannah,
Thanks for letting us know and for providing an update. As you said, it sounds like you didn’t cause the root issue, but good to identify stuff to do next time.
Ivor
To provide an interim update from the woodtechs, we are looking into replacing the matt with a tougher alternative. This may take a couple of weeks, due to some budget uncertainties. We will report once the issue is resolved.
Ivor
Hi in meantime is it ok to use planar thicknesses for smaller pieces, that don’t require moving the machine?
If you can access entry and exit safely, then I don’t see an issue with using it. Please take some time to clean up thoroughly after, so that woodchips don’t get caught under the torn liner.
Might also be a good idea to check if the rubber pads under the ‘hovercraft’ aren’t damaged, if they are it may have caused the machine to become harder to move resulting in the damaged underlay.
I’ve managed to remove the bit of wood stuck under it, it doesn’t move too well so I’d recommend leaving it in position, but I see no reason it can’t be used
Just waiting for a reply from the @directors regarding funds, then we can get it sorted. I am back next week so can check the hovercraft pads
