I feel a bit out of my depth with this but I think someone here may be able to help or offer some advice.
My PC has been randomly shutting down whenever I am in the middle of playing Valorant.
When I check the event viewer it says that a Kernal 41 error has taken place.
I did some research and thought it may be an issue with a power supply, so then I changed the PSU. Nothing.
I got myself a new GPU
Nothing.
So now I have no clue what’s causing the issue and really want to get fixed. Can anyone offer any advice?
If the PSU and the GPU are new but the computer still crashes then that leaves the CPU and the memory as the most likely culprits. I suggest you run a memory check as Dan said, but I also suggest installing HWMonitor[1] and keeping an eye on temperature levels. Most modern processors will auto shut off if their temperature goes up too high. Valorant is a CPU-heavy game and could be pushing your temps a bit too high. Look up your CPU maximum operating temperature and see if you’re spending too much time at or above it.
