Onshape guidance (2D sketches and 3D tools for organic curve parts): Iron Man-style armor
Hi,
My name is Godfrey Ampoma. I’m designing a wearable Iron Man-style suit in Onshape from my body measurements. I have body measurements. What I find tricky is choosing 2D sketches and 3D tools strategy for curved parts and getting parts to fit. I have experience with Autodesk Inventor, SolidWorks, and AutoCAD, but I’m finding the transition to organic, curved armor shapes challenging. I’m looking for guidance on which 2D sketches and 3D tools I should use for my armor. Does anyone have experience with cosplay armour to review my part designs and advise on 2D sketches and 3D tools choices and sizing?
(just my 2 cents, I realize I’m not answering your question exactly…)
Have you tried/considered using something like Blender?
In my mind, 3D design is a bit split between “technical stuff”, with measurements and precision and blueprints and etc, and “organic stuff”, like figurines, sculptures, etc, etc.
You can do both types of things with both types of software… But most will be easier in one or the other.
For example, if I’m 3d-printing something to hold stuff around a shelf, or clips to join things together, or something “generally functional”, i’d use CAD, but if i wanted to 3D print something nice-looking and non-functional, i’d use something in the Blender type of software.
An Iron-man armor kinda falls in between those two, since it need to be functional and have actual measurements matching your body… Plus you might want to have mechanisms around the face / arms / etc that could benefit from CAD.
But it’s also very “organic” and looks will probably matter more than precise parametric design… And more importantly in my mind, I expect there are hundreds of 3D models of iron-man you can take and adapt. These will be meshes, not parametric / STEP files, and you’ll have a much easier time, IMO, modifying a mesh of triangles in Blender than in CAD (again, both can do it… but CAD is not built around mesh manipulation as much).
If I were doing this myself (and I’ve thought about it many times :smiley: ), I would start with an existing mesh and start “skewing” things to fit my body, as opposed to start designing from scratch.
Again, just my 2p
Hi Daniel,
Thank you so much for taking the time to reply. I really appreciate your advice. I’ve stuck with Onshape because I need everything to fit my exact body measurements and work with 3D printing, flexible joints, and electronics but you’re right that the curved armor shapes are much harder in CAD. I already have Blender installed and I import the part of my helmet from Onshape to Blender via STL. I also tried Blender’s Paper Model tool to unfold the part of my helmet but ran into errors I couldn’t fix. I also really like your idea of starting from an existing mesh and adapting it. That sounds like a much smarter way to get the look right from the start. Do you have any recommendations on where to find good Iron Man-style models that I could adjust to fit my measurements?
Thank you for your help. I really appreciate it.
