Need help scoping a table top CNC machine
I’m considering buying a mid range table top CNC machine something with a > 50cm by 50cm bed range that can easily cut thin aluminum and brass would be also helpful for some of my restauration work (but not essential for the current project). I was looking at a closed loop systems around the £2k mark. Does anyone have any alternative suggestions, no build it yourselves projects, this has to work out the box pretty much.
FoxAlien https://www.foxalien.com/products/cnc-router-machine-cl-6560?_pos=3&_sid=5ae3e1565&_ss=r
Be great to buy British if possible :slight_smile:
Check out here, well known uk firm
You must be psychic - I was going to suggest them as well !
