The tool control Elves were busy again this weekend.
The metal area got a reader for the metal lathe in preparation for the soon to be available inductions, as did the Mini CNC.
Woodshop master power is working under control now and you will need a Tech present to use any of the bigger tools which are now (for the time being) on the key over ride.
Preparation for the control of the Laser is under way.
This will soon be managed from the reader that is already mounted on the wall next to the PC. Please try your tag if you are passing to make sure you have permissions (if you have passed an induction), let us know if you believe there is an error.
Work continues in the background and I’ll do some more updates as things progress.
Courty and @systems
