More laser fun - a card box
Tried out the laser cutter again this weekend - this time it’s a card box for a game called Anomia. I got to use the frame clamp (is that what it’s called?), which worked wonders for the glue-up. Used fine grit sand paper to remove the laser-burn marks from the surfaces and chamfer the edges down as a final step.
Very very well tuned engraving paramethers!
Looks beautiful!
Great work and good to see the 4-cornered expandable clamp being put to good use :slight_smile:
Thanks! Shout out to @Amit_Kohli’s 3mm ply settings!!
