Modular Model Railway Baseboard
Originally published at: http://southlondonmakerspace.org/2016/04/04/modular-model-railway-baseboard/
I needed to build a modular baseboard for a model railway, to replace previous attempts
Goals
  • Around 1200 x 600mm
  • Ability to be dismantled and moved by one person
  • Made out of wood
  • Simple construction
  • Repeatable & easy to manufacture
  • Contains all necessary electronics / point motors etc…
  • Not too expensive
Build / Design Log
After being inducted to use the Trotek Speedy 300 at the South London MakerSpace I had the ability to precisely cut wood, this i thought would be a good excuse to design and build such a module.
Design Stage
I had not used any CAD programs so looked at what was free, all programs had a rather large learning curve but I chose SketchUp.
After what seemed like an age trying to figure out how to get SketchUp to play ball I started to figure out.
The laser cutter has a bed of 726 x 432mm so to make 1200mm long sections there will need to be a join, also one of the main sizes that laser Plywood comes in in 400 x 600mm.
The First Bit to design was the End Wall, this needs to mate up against another unit so is (like all parts) symmetrical.
end_wall_
Then the side walls, since each board will need four sides i needed a method of joining them, i went for a dovetail arrangement and the top board also spanned the join to give more re-enforcement.
sides
Much like drawing an owl the design was then complete.
compete_board
Build Stage
So I needed to get a 2d SVG out of SketchUp, I used the modified FlightsOfIdeas plug-in to do this, this can be found at Git Hub and installed manually into SketchUp.
This meant that I then had a number of SVG files for each component, I placed these flat and merged them to maximize the usage of the Laser Ply in Incscape.
This meant that out of 11-12 400x600mm boards i could make 2, 1200 x 600mm Baseboards.
svg_file_end
Cutting
Once I had the SVG files, they were sent to the Laser cutter, this is done “simply” by Ctrl P and choosing the laser cutter as a printer.
You have to go through some set up, thickness of material, speed and number of cuts etc…. after sending all of these to the printer the parts were cut.
Unfortunately I did not get any videos / images of the laser cutter cutting, however here are the results of the cut parts put together to test the fit.
photo_2016-04-02_18-22-06
Construction
Once all the parts had been competed, the modules were glued and left to go off, a completed baseboard can be seen below.
photo_2016-04-02_18-04-28
Both units are 1.2m long by 0.6m wide, the dovetail joints are re-enforced with a wood square glued behind it.
The underside of the baseboard, was designed to hold all of the electronic modules some of these were installed along with the USB / to MERG CBus control module.
photo_2016-04-02_18-03-56
Conclusion
In conclusion the baseboards fit well together and were much more precise then my previous attempts, it took a little while to get the tolerances correct as you have to take into the kerf of the Laser cutting beam, SketchUp whilst has quite a steep learning curve I found great for visualizing the parts and how they would all fit together.
The next design will need a curved section so this should be an interesting challenge.
Looking great.
But no author!
@Tim this is you?
Correct :slight_smile:
This is in the blog category, so has been posted from the main Makerspace site. If you look there, the author is listed. I wonder if there’s some kind of hook to include the author tag here in Discourse, ie. extending the ‘Originally published at’ line.
Not a priority, though.
Also: model railways! One thing I don’t get: if these are to be modular, how do they interlock?
The version on the blog has been edited , but the edits don’t propagate to Discourse.
Toby,
You see on the end block there are two circular holes (below), and one oblong in the centre, the two holes on the outside edge take a dowel of the same diameter.
This will then be affixed to one baseboard with the Dowel sticking out. This means the hole of the adjoining board can push over it, with a bolt through the center to hold it all together.
I can dig out a still from SketchUp showing this detail if you want.
Ah, gotcha.
