Mini CNC
Hi @CNCtechs
I’ve been using the mini CNC this afternoon.
The USB port in the laptop seems a little janky - wasn’t always able to use it to transfer files - I used the one the keyboard was plugged into.
Also, is there a battery around for the digital calipers?
Cheers
Rob
Yes we are aware of the usb issue, we are in the process of reconfiguring the area, so we will look into that too.
Federico
OK - thanks - was worried I was the first to screw it up!
If you’re lucky, there might be some in the chest of drawers in the clean room where the line wobbler lives. I donated a bunch a little time ago, though haven’t checked recently.
What size are needed? I have loads at home and will happily donate
There were also some of those batteries in the electronics area, in the corner by 3D printing - @platinumnqueen22 showed me where when I needed to replace a battery for digital calipers.
From memory I think they’re the typical LR44 size.
Hi :smiley: :thinking: The calliper batterys are on the electronic bench in a smaal cute white tub with little blue handles . Keep well. Brian D=
I’ve changed it
