Hi guys,
Just to let you know that Henry the vacuum cleaner on top of the mini cnc is not working and it’s unplugged.
The cnc works correctly but there is no dust extraction system at the moment
@cnctechs
Federico
Hi guys,
@cnctechs
Federico
Thanks @Federico! Will take a look!
I think I’ve got a spare motor languishing in my garage (SW19) if you need it.
I also have a spare Hoover (Spritz model, bagless) I can bring to the space but it’s smaller and less powerful than Henry
Federico
Hi all, check to see if it has been emptied as some of the henry models have an automatic cut off if it is full, Brian D=
If it’s the one I rescued from a fly tip, the fix at the time was cleaning the contacts in the power switch.
I came in and checked it and it seems to work. I emptied just a bit out of the bag, I suspect someone did it before me.
Hi guys,
I emptied with @Howard 's help when stopped working, but it didn’t solve the problem.
So is it working now?
Federico
Just as an ‘aside’. Do you completely unwind the cable for Henry when used as cnc extractor?
No, i left as it was.
We changed the bag and it sucks again! So Henry should be all good
