Mini CNC help tonight?
hello - my induction for the MiniCNC was a while ago and I want to percisely machine out some wood, I have a DXF profile I need the final shape to be but could use some help getting a path set up on Autodesk…
If there is anyone in tonight able to assist that would be great
Definetly owe you a beer from next door after! Kind regards,
Matthew
@CNCtechs?
I’ll be around tomorrow or Sunday if you can change day, but @christian is way more competent than me in the manufacturing side of fusion 360
If it’s just a profile, vcarve should handle it just fine. The manufacturer video from the induction should guide you there.
Not a cnc tech but done a bit and down the space now. Hopefully can help
I’m just back in the UK today. Is help still needed? I don’t know exact which day I’m in but let me know if you need us.
Kyle’s suggestion is not bad. Maybe try and see if the induction video gets you there? You can always trial and error a bit with leftover wood from the woodshop. Might get you there faster than waiting for me.
