Mini cnc feedrates for aluminium
Tags: #<Tag:0x00007fa360430778> #<Tag:0x00007fa360430548>
@CNCtechs > I’ve got a need to mill some 2mm aluminium plate on the CNC machine and plan to first check that my settings are ok on plywood, but I haven’t had much experience milling Alu on this machine - anyone could recommend some feedrates, depth of cuts, etc?
Thinking of using a 3mm drill bit as that’s the size of the holes I will have in there.
Thanks!
Just replied on another thread, hopefully that helps
