MIG gas is out?
Tags: #<Tag:0x00007fa4a392c648>
@Metaltechs believe you are aware the MIG gas is out. Do I understand correctly a cylinder is on order?
Apols if this has been posted elsewhere and I’ve missed it, but wanted others to be aware in case they also can’t do their welding projects today.
Hello, new cylinder has been delivered today, I’ll be in shortly to connect it.
Thanks @scythian, I’ll wait for you then, thanks
can we write out a process for replacing the bottles and put it near the canisters? or have some way of marking used ones.
Ive been in the space when a guy comes by to exchange the tanks but didnt know what to give him.
rule of thumb is it has a red/yellow plug on it it is full, if it’s connected to the welding machine it’s half… erm full, everything else is empty
Hi @metaltechs
Did the MIG gas get changed yesterday and is the welder ready to use?
yes that was replaced and flow set up to regular 10l/min. note that’s a new larger cylinder, with a slightly different layout of the tap/regulator
