Metalwork sensor needs charging
@metaltechs or anyone else, would you mind charging the light sensor in the metalwork area. No sleep last night and plugged the charger into the welding area instead, just needs swapping over, can be done with an extension lead or a power bank,
Cheers
Bumping this can someone please charge this
Hi Mark, the metal shop is powered up now as someone is using it so I assume this is charging up - it’s still plugged in and switched on. Let me know if there’s something else I should do.
Don’t worry, I came in and did it myself
